Zum Hauptinhalt wechseln
Acer Chromebook C720 Heat Sink and Cooling Fan Replacement
Was du brauchst
  1. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: Schritt 1, Bild 1 von 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: Schritt 1, Bild 2 von 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: Schritt 1, Bild 3 von 3
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 3mm screws securing the heat sink using the Phillips #0 screwdriver.
    • Remove the two 3mm screws securing the fan using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 3, Bild 2 von 2
    • Gently pry the fan module away from the motherboard. After a bit of force, it should pop out of its slot.
    • Carefully unwrap the wires from around the fan.
  4. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: Schritt 4, Bild 3 von 3
    • Gently disconnect the fan module from the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team S2-G5, Harley Spring 2019 Mitglied von IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 514
