Zum Hauptinhalt wechseln
Acer Chromebook C720 Solid State Drive (SSD) Replacement
Was du brauchst
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): Schritt 1, Bild 1 von 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): Schritt 1, Bild 2 von 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): Schritt 1, Bild 3 von 3
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: Schritt 2, Bild 3 von 3
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C720 Solid State Drive (SSD) Replacement: Schritt 3, Bild 2 von 2
    • Gently remove the SSD from the motherboard.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S2-G5, Harley Spring 2019 Mitglied von IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - Antwort
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 111
Insgesamt: 6,578
