Zum Hauptinhalt wechseln
Acer Chromebook C720-2103 Battery Replacement
Was du brauchst
  1. Acer Chromebook C720-2103 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2103 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Battery Replacement: Schritt 2, Bild 1 von 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Battery Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2103 Battery Replacement: Schritt 4, Bild 2 von 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Battery Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C720-2103 Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Matthew Holt
633 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S66-G3, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 789
