Einleitung
This guide describes how to properly remove the battery of the Acer Chromebook C720-2103. It can be referenced for a temporary removal, while replacing another component, or for the batteries replacement.
A battery replacement is recommended if the device no longer holds a charge or if the battery is faulty.
- The plastic outer casing is easy to damage during removal. Take your time and be careful.
- Make sure the device is powered off during this replacement. There is a possibility of electrocution.
Was du brauchst
Shut the device off.
Turn the device over so the bottom is facing up.
Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
Wedge a plastic opening tool between the back casing and the rest of the device.
Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
Eine weitere Person hat diese Anleitung absolviert.
