Einleitung
This guide explains how to properly remove the fan of the Acer Chromebook C720-2103. It can be referenced for temporary removal, while replacing another component, or for the fans replacement. This is a moderately hard replacement, requiring the removal of the battery first.
A fan replacement may be necessary if the device is experiencing unexpected shutdowns due to overheating.
- Be extremely gentle while handling internal components of the device, most are very fragile.
- Make sure the device is powered off during this replacement. There is a possibility of electrocution.
Was du brauchst
Shut the device off.
Turn the device over so the bottom is facing up.
Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
Wedge a plastic opening tool between the back casing and the rest of the device.
Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
Remove all four 6mm screws attaching the fan to the motherboard with a Phillips #0 screwdriver.
Remove the two 6mm screws attaching the fan to the device base with the Phillips #0 screwdriver.
Unsnap the two coaxial connectors from the motherboard.
Unhook the coaxial wires from the side of the fan by gently pulling them downward and away from the hooks.
Peel up the tape attaching the rainbow connector wire to the motherboard, but leave the tape attached to the wire itself.
Pull the rainbow cable connector out of the black terminal by wiggling it gently from side to side with your fingers.
Lift the fan component up and out of device with your hands. Take care not to knock the fan against the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
