Zum Hauptinhalt wechseln
Acer Chromebook C720-2103 Solid State Drive Replacement
Was du brauchst
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 2, Bild 1 von 1
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 4, Bild 2 von 2
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: Schritt 6, Bild 1 von 1
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook C720-2103 Solid State Drive Replacement: Schritt 7, Bild 3 von 3
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Holt
633 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S66-G3, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 275
