Einleitung
This guide goes through the steps on how to replace the solid state drive for the Acer Chromebook C720-2103. This is a fairly easy replacement guide and only need the knowledge for the use of a Phillips screwdriver. The main part of the replacement guide is removing screws, the battery and the actual part. There is also a removable of one simple cable. Make sure the device is powered off during this replacement as there is a possibility of electrocution.
Was du brauchst
Shut the device off.
Turn the device over so the bottom is facing up.
Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
Wedge a plastic opening tool between the back casing and the rest of the device.
Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
