Einleitung
This guide will provide you with simple and clear steps on how to replace the motherboard on an Acer Chromebook C720-2420.
Was du brauchst
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
Remove the six 4.7 mm Phillips screws that secure the fan.
Disconnect these cables from the motherboard using the tweezers.
Pull out the fan.
Lift up the black tab on the ZIF connector to release the ribbon cable.
Carefully remove the ribbon cable.
Gently remove the ribbon cable
Remove the ribbon cable.
