Zum Hauptinhalt wechseln
Acer Chromebook C720-2420 Motherboard Replacement
Was du brauchst
  1. Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: Schritt 1, Bild 2 von 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Motherboard Replacement, Battery: Schritt 3, Bild 1 von 2 Acer Chromebook C720-2420 Motherboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2420 Motherboard Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery.
  6. Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: Schritt 6, Bild 1 von 2 Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: Schritt 6, Bild 2 von 2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook C720-2420 Motherboard Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook C720-2420 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
  8. Acer Chromebook C720-2420 Motherboard Replacement, Memory: Schritt 8, Bild 1 von 2 Acer Chromebook C720-2420 Motherboard Replacement, Memory: Schritt 8, Bild 2 von 2
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  9. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook C720-2420 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Pull out the SSD.
  10. Acer Chromebook C720-2420 Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Disconnect the speaker cable from the motherboard.
  11. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the display cable from the motherboard.
  12. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Gently pull out the wire for the 2 PIC connectors.
  13. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
  14. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Carefully remove the ribbon cable.
  15. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Gently remove the ribbon cable
  16. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Remove the ribbon cable.
  17. Acer Chromebook C720-2420 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Lift up and remove the motherboard.
Abschluss
USF Tampa, Team S15-G4, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 14
Letzte 30 Tage: 44
Insgesamt: 591
