Zum Hauptinhalt wechseln
Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement
Was du brauchst
    1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: Schritt 1, Bild 2 von 2
      • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 2, Bild 2 von 2
      • Pry the back panel open with the plastic opening tool.
      Frag FixBot
    1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Battery: Schritt 3, Bild 1 von 1
      • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
      Frag FixBot
    2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 4, Bild 2 von 2
      • Carefully pull out the battery wire connected to the battery port.
      Frag FixBot
    3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 5, Bild 1 von 1
      • Slowly lift the battery to remove it from the Chromebook.
      Frag FixBot
    1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: Schritt 6, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: Schritt 6, Bild 2 von 2
      • Unplug the speaker wire from the motherboard.
      Frag FixBot
    2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 7, Bild 2 von 2
      • Carefully pull out the speakers from each side of the Chromebook.
      Frag FixBot
    1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: Schritt 8, Bild 1 von 3 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: Schritt 8, Bild 2 von 3 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: Schritt 8, Bild 3 von 3
      • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
      • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
      Frag FixBot
    2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 9, Bild 2 von 2
      • Position the spudger under the switch that connects the ribbon cable to the motherboard.
      • Flick the spudger up to flip the switch up.
      Frag FixBot
    3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 10, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 10, Bild 2 von 2
      • Pull the blue tab on the ribbon cable to remove it.
      Frag FixBot
    4. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 11, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 11, Bild 2 von 2
      • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
      • Pull each piece of circuitry out of the Chromebook and remove it from the device.
      Frag FixBot
    5. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 12, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 12, Bild 2 von 2
      • Position the spudger under the switch.
      Frag FixBot
    6. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 13, Bild 1 von 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: Schritt 13, Bild 2 von 2
      • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
      • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team S4-G7, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S4-G7, Julie Fall 2017
UMASSD-JULIE-F17S4G7
1 Mitglied
45 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 679
