Einleitung
This guide will walk you through replacing the trackpad of your device. It's a moderate process, and you'll need a Phillips #0 screwdriver to complete this guide.
Was du brauchst
Use a Phillips head screw driver to remove the 13 screws in these locations.
Remove the trackpad ribbon cable.
To do this, lift the small black component; it is hinged to the white component.
Then simply pull the ribbon cable out of the connector.
Remove the small metal frame by simply lifting it out.
Carefully peel up the tape holding the trackpad in place.
Remove the trackpad from the computer frame.
