Zum Hauptinhalt wechseln
Acer Chromebook C731-C8VE Battery Replacement
Was du brauchst
  1. Acer Chromebook C731-C8VE Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Battery Replacement: Schritt 2, Bild 1 von 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE Battery Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C731-C8VE Battery Replacement: Schritt 3, Bild 2 von 2
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Battery Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook C731-C8VE Battery Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook C731-C8VE Battery Replacement: Schritt 4, Bild 3 von 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Battery Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook C731-C8VE Battery Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook C731-C8VE Battery Replacement: Schritt 5, Bild 3 von 3
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 324
