Einleitung
This is the display assembly replacement guide for the Acer Chromebook C731-C8VE. By following the guide, you should be able to completely remove the screen from your device.
Make sure to follow all hazard warnings for your safety.
Was du brauchst
Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
The 2 mm screws marked orange have washers attached and must be placed in these specific areas.
These 2 mm screws do not have washers and will be located on the left and right of the device.
Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
Use the JIS #00 screwdriver to remove the four 1.5mm screws that connect the base of the laptop to the screen. There are two screws on each latch.
Carefully detach the cables that connect the screen to the motherboard. This includes a black display cable that connects to the mother board and two wires that connect to the Wi-Fi card.
