Zum Hauptinhalt wechseln
Acer Chromebook C731-C8VE Trackpad Replacement
Was du brauchst
  1. Acer Chromebook C731-C8VE Trackpad Replacement, Trackpad: Schritt 1, Bild 1 von 1
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and must be placed in these specific areas.
    • The 2 mm screws marked orange do not have washers attached and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 3, Bild 1 von 3 Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 3, Bild 2 von 3 Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 3, Bild 3 von 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 5, Bild 2 von 2
    • Use the JIS #00 screwdriver to remove four 1mm screws that connect the trackpad to the device.
  6. Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook C731-C8VE Trackpad Replacement: Schritt 6, Bild 2 von 2
    • Do this step slowly to ensure that you do not damage the trackpad or the device.
    • Remove the trackpad from the base of the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 179
