Zum Hauptinhalt wechseln
Acer Chromebook C731-C8VE Wi-Fi Card Replacement
Was du brauchst
  1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 1
    • Place Chromebook face down.
  2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2mm screws have washers and must be placed in these specific areas.
    • The 2mm screws marked orange do not have washers and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 4, Bild 3 von 3
    • Detach the two wires that connect the Wi-Fi card to the screen.
    • The white wire will attach to the top and the black wire to the bottom.
  5. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Use the JIS #00 screwdriver to unscrew the single 1mm screw connecting the Wi-Fi card to the base.
    • Once the screw is removed, the Wi-Fi card will pop up.
  6. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Remove the Wi-Fi card from the motherboard.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 173
