Zum Hauptinhalt wechseln
Acer Chromebook C740 Battery Replacement
Was du brauchst
  1. Acer Chromebook C740 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C740 Battery Replacement: Schritt 2, Bild 2 von 2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Battery Replacement: Schritt 3, Bild 1 von 3 Acer Chromebook C740 Battery Replacement: Schritt 3, Bild 2 von 3 Acer Chromebook C740 Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Acer Chromebook C740 Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Acer Chromebook C740 Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Acer Chromebook C740 Battery Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C740 Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Acer Chromebook C740 Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery from the frame.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S22-G2, Livingston Spring 2017 Mitglied von Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 7,339
