Zum Hauptinhalt wechseln
Acer Chromebook C740 LCD Screen Replacement
Was du brauchst
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C740 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook C740 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: Schritt 6, Bild 1 von 3 Acer Chromebook C740 LCD Screen Replacement: Schritt 6, Bild 2 von 3 Acer Chromebook C740 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S22-G2, Livingston Spring 2017 Mitglied von Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 3,307
