Zum Hauptinhalt wechseln
Acer Chromebook C740 Motherboard Replacement
Was du brauchst
  1. Acer Chromebook C740 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C740 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Motherboard Replacement: Schritt 3, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 3, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Flip up the clip holding down the white cable using the spudger.
    • Pull the cable outwards towards the battery.
  5. Acer Chromebook C740 Motherboard Replacement: Schritt 5, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 5, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Flip up the clip holding down the white cable using the flat end of the spudger.
  6. Acer Chromebook C740 Motherboard Replacement: Schritt 6, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 6, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Flip up the white clip holding down the connector labelled "MB" using the flat end of the spudger.
    • Remove the connector by pulling out towards the battery.
  7. Acer Chromebook C740 Motherboard Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  8. Acer Chromebook C740 Motherboard Replacement: Schritt 8, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 8, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Unplug the black connector attached to the motherboard at the top right of the battery by using a spudger to push the two L-shaped indentations towards the battery.
  9. Acer Chromebook C740 Motherboard Replacement: Schritt 9, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 9, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Peel back the tape covering the white connector at the top-right of the motherboard.
    • Remove the connector from its fitting by pulling outwards.
  10. Acer Chromebook C740 Motherboard Replacement: Schritt 10, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 10, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Unplug the white connector attached to the right of the fan with the spudger by applying force towards the battery on the two L-shaped indentations.
  11. Acer Chromebook C740 Motherboard Replacement: Schritt 11, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 11, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Disconnect the two white and black wires by holding close to the metal snap-on caps and pulling upwards.
  12. Acer Chromebook C740 Motherboard Replacement: Schritt 12, Bild 1 von 2 Acer Chromebook C740 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the four 3.7 mm screws with a Phillips #0 screwdriver.
  13. Acer Chromebook C740 Motherboard Replacement: Schritt 13, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 13, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Loosen the two black screws with a Phillips #0 screwdriver.
    • These screws cannot be removed. However, simply loosening them allows the heatsink fan to lift away from the motherboard.
    • Lift the heatsink fan and rotate it away from the mother board to set down outside the laptop.
  14. Acer Chromebook C740 Motherboard Replacement: Schritt 14, Bild 1 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 14, Bild 2 von 3 Acer Chromebook C740 Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the 3.63 mm screw in the top right near the hinge with a Phillips #0 screwdriver.
    • Remove the 3.75 mm screw near the top right corner of the battery with a Phillips #0 screwdriver.
  15. Acer Chromebook C740 Motherboard Replacement: Schritt 15, Bild 1 von 2 Acer Chromebook C740 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  16. Acer Chromebook C740 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Unplug the solid state drive.
  17. Acer Chromebook C740 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Carefully lift the motherboard away from the laptop with two hands.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
William Yu
283 Reputation
1 Anleitung geschrieben
Cal Poly, Team S22-G2, Livingston Spring 2017 Mitglied von Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 30
Insgesamt: 3,402
