Was du brauchst
Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
Using the spudger or other prying tool, gently pry the back off of the device.
Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
Detach the connecting cable from the motherboard by pulling away.
Remove the battery from the device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
