Zum Hauptinhalt wechseln
Acer Chromebook C740-C4PE Battery Replacement
Was du brauchst
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook C740-C4PE Battery Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook C740-C4PE Battery Replacement: Schritt 4, Bild 3 von 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob Kahn
273 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 472
