Zum Hauptinhalt wechseln
Acer Chromebook C740-C4PE Heatsink Replacement
Was du brauchst
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: Schritt 1, Bild 1 von 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: Schritt 1, Bild 2 von 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: Schritt 1, Bild 3 von 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 3, Bild 2 von 2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 4, Bild 1 von 1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 5, Bild 1 von 1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 6, Bild 1 von 1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: Schritt 7, Bild 1 von 1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dylan Tocci
237 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
What type of thermal paste is best used?
Tracey Arria - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 349
