Einleitung
This repair guide will demonstrate the process of removing the battery for the Acer Chromebook CB0311-1H-C1MX laptop. The battery is responsible for powering the chromebook and ensuring that it stays mobile and efficient. The battery may need to be removed if there are issues with the device holding a charge or powering on. Make sure to disconnect the laptop from all sources before continuing.
Was du brauchst
Using a JIS #1 screwdriver, remove eleven 6.6 mm screws from the back cover.
Beginning at the hinges, use an iFixit Opening Tool to pry open the back case.
Continue using the iFixit Opening Tool around the entire edge of the case.
Using a JIS #1 screwdriver, remove all four 4.8 mm screws holding the battery in place.
Gently push on either side of the silver connector so that it no longer covers the battery cable.
Disconnect the battery cable by pulling it straight out.
2 weitere Personen haben diese Anleitung absolviert.
