Zum Hauptinhalt wechseln
Acer Chromebook CB0311-1H-C1MX Heatsink Replacement
Was du brauchst
  1. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a JIS #1 screwdriver, remove eleven 6.6 mm screws from the back cover.
  2. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: Schritt 2, Bild 1 von 1
    • Beginning at the hinges, use an iFixit Opening Tool to pry open the back case.
    • Continue using the iFixit Opening Tool around the entire edge of the case.
  3. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using a JIS #1 screwdriver, remove all four 4.8 mm screws holding the battery in place.
  4. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: Schritt 4, Bild 2 von 2
    • Gently push on either side of the silver connector so that it no longer covers the battery cable.
    • Disconnect the battery cable by pulling it straight out.
    • This component is called the Flat Topped Connector.
  5. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: Schritt 5, Bild 2 von 2
    • Lift and remove the battery from the laptop.
  6. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Heatsink: Schritt 6, Bild 1 von 2 Acer Chromebook CB0311-1H-C1MX Heatsink Replacement, Heatsink: Schritt 6, Bild 2 von 2
    • Remove all four 4.7 mm screws from the heat sink with the JIS #1 screwdriver.
  7. Acer Chromebook CB0311-1H-C1MX Heatsink Replacement: Schritt 7, Bild 1 von 1
    • Remove the heatsink from the laptop.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 130
