Einleitung
Use this guide to replace the screen of your Acer Chromebook CB3-111-C670. The screen replacement is a simple fix, and shouldn't take long at all.
Was du brauchst
Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
Once you've removed the screws, lift the piece of tape that is covering the display connector.
Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
