Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The Acer Chromebook CB3-111-C670 uses an Intel WLAN Wireless Board 7260NGW. This guide will teach you how to disassemble your Chromebook and replace the WLAN chip.
  1. Turn the Chromebook over so that the back panel with the tag and serial number is facing upward.
    • Turn the Chromebook over so that the back panel with the tag and serial number is facing upward.
    • Locate the twelve screws and unscrew them using your nut/screw driver.
    • After removing each of the twelve screws, use a plastic opening tool to detach the back panel by inserting it in between crease where the back panel and the main board meets. You should hear a slight click, this is the sound of the back panel becoming detached from the board.
    • The best way to do this is to start at one of the four corners of the Chromebook and gently work around the edges. Be careful not to apply too much force or else you might damage the ribbon cable which connects the back panel to the motherboard.
    • Once you have detached the back panel, do not lift it vertically from the Chromebook. With the Chromebook facing in the direction of the picture above, take the right hand side of the back panel and lift it toward the left as if you are opening a book.
  2. Locate the WLAN chip near the top left corner of the motherboard. It is connected to the left edge of the motherboard and has two smaller wires connected to the wireless adapter itself. First, grasp the top and bottom edge of chip using your fingers and gently disconnect it from the motherboard. TheWLAN chip  has two small wires connected to it, which can be disconnected from the card by pulling them very gently.
    • Locate the WLAN chip near the top left corner of the motherboard. It is connected to the left edge of the motherboard and has two smaller wires connected to the wireless adapter itself.
    • First, grasp the top and bottom edge of chip using your fingers and gently disconnect it from the motherboard.
    • TheWLAN chip has two small wires connected to it, which can be disconnected from the card by pulling them very gently.
  3. Insert the new chip and reattach the two wires before putting the chip back into the motherboard.
    • Insert the new chip and reattach the two wires before putting the chip back into the motherboard.
    • Put the backing of the Chromebook on and screw in the 12 screws as seen in step one.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
lott
311 Reputation
1 Anleitung geschrieben
USF Tampa, Team 10-5, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 10
Insgesamt: 1,340
