Zum Hauptinhalt wechseln
Acer Chromebook CB3-111-C8UB Back Panel Removal
Was du brauchst
  1. Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: Schritt 1, Bild 1 von 2 Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: Schritt 1, Bild 2 von 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Back Panel Removal: Schritt 2, Bild 1 von 3 Acer Chromebook CB3-111-C8UB Back Panel Removal: Schritt 2, Bild 2 von 3 Acer Chromebook CB3-111-C8UB Back Panel Removal: Schritt 2, Bild 3 von 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Back Panel Removal: Schritt 3, Bild 1 von 2 Acer Chromebook CB3-111-C8UB Back Panel Removal: Schritt 3, Bild 2 von 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
Abschluss
Travis Vo
426 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 22-7, Maness Winter 2017 Mitglied von Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
When I removed the screws from the bottom (Step 1), the 8 screws closest to the hinge were 7mm, and the front 4 were 5mm. Hope this helps someone in the future.
lumberjackdavid - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 1,824
