Einleitung
Use this guide to replace the speakers in your device.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
Unplug the cable by putting both thumbs on each tab and unlocking the cable by pushing the tabs away.
Remove speakers by placing index finger on top and thumb on bottom of the speakers.
Peel speakers away from the base that is connected by an adhesive.
Peel the black cord connecting the two speakers together away from the Velcro located at the midpoint between the two speakers.
Remove speakers from laptop.
Ein weiterer Nutzer hat diese Anleitung absolviert.
