Zum Hauptinhalt wechseln
Acer Chromebook CB3-131-C3KD Track pad Replacement
Was du brauchst
  1. Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 3, Bild 2 von 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: Schritt 6, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement, Trackpad: Schritt 6, Bild 2 von 2
    • Remove the (3) three 7.0mm screws using the J0 screwdriver head.
  7. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 7, Bild 2 von 2
    • Unlock the latches on both ends of the ribbon cable, and pull to detach.
    • The ribbon cable will still be attached to the tape.
  8. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 8, Bild 1 von 1
    • Peel the tape that is on top of the trackpad.
  9. Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook CB3-131-C3KD Track pad Replacement: Schritt 9, Bild 2 von 2
    • Lift the trackpad out of the Chromebook.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ashley Oxner
731 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S11-G1, Passmore Fall 2017 Mitglied von USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 437
