Einleitung
This is a fairly easy repair and only requires a Phillips #0 screwdriver and a plastic spudger. Before beginning this repair, make sure to completely power down your computer as it is dangerous to work on the internals of the computer while it is running. Also, remember to handle all of the internal components of your Chromebook with care as they are fragile.
Was du brauchst
Remove the eight 4mm Phillips #0 screws.
Remove the two 6mm Phillips #0 screws.
Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
Remove the bottom panel and set it aside.
