Zum Hauptinhalt wechseln
Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement
Was du brauchst
  1. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the Chromebook over so the bottom is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 2, Bild 1 von 1
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
    Frag FixBot
  3. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 3, Bild 2 von 2
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
    Frag FixBot
  4. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 4, Bild 2 von 2
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
    Frag FixBot
  5. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement, Daughterboard: Schritt 5, Bild 1 von 1
    • Detach the four cable connectors from the daughterboard.
    Frag FixBot
  6. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the two silver screws with a Phillips #1 screwdriver.
    • Remove the two black screws with a Phillips #1 screwdriver.
    Frag FixBot
  7. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 7, Bild 2 von 2
    • Lift up the metal hinge.
    Frag FixBot
  8. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the daughterboard from the laptop.
    Frag FixBot
Abschluss
UMass Dartmouth, Team 1-5, Santin Spring 2024 Mitglied von UMass Dartmouth, Team 1-5, Santin Spring 2024
UMASSD-SANTIN-S24S1G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 532
