Zum Hauptinhalt wechseln
Acer Chromebook CB315-3HT-C3FQ Display Replacement
Was du brauchst
  1. Acer Chromebook CB315-3HT-C3FQ Display Replacement, Display: Schritt 1, Bild 1 von 1
    • Pop off the front panel that holds the Acer Chromebook's LCD screen.
    • If you are struggling to remove the front panel, you can always use a Jimmy to remove the panel.
  2. Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove ten screws that are holding the LCD screen to the top-half of the Acer Chromebook as marked in the image provided.
  3. Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 3, Bild 2 von 2
    • Remove the transparent tape used to hold the LCD connector.
  4. Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 4, Bild 3 von 3
    • Pull out the double-sided tape that is attaching the LCD screen to the frame of the Acer Chromebook by grabbing the tip of the tape (it should be poking out above the LCD screen) and pulling away from the frame.
    • If you're having trouble removing the tip of the double-sided tape, you can use a metal spudger to separate the tip from the frame.
  5. Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook CB315-3HT-C3FQ Display Replacement: Schritt 5, Bild 2 von 2
    • After pulling out the double-sided tape, remove the LCD screen by simply popping it out of the frame.
    • At the bottom of the LCD screen, there will be a QR code that can be scanned on your phone. The QR code will take you to different websites that sell the designated LCD screen for the Acer Chromebook 315.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kyle
327 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Santin Spring 2024 Mitglied von UMass Dartmouth, Team 1-5, Santin Spring 2024
UMASSD-SANTIN-S24S1G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 149
