Zum Hauptinhalt wechseln
Acer Chromebook CB5-132T-C8ZW USB Port Replacement
Was du brauchst
  1. Acer Chromebook CB5-132T-C8ZW USB Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
  2. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 2, Bild 2 von 2
    • Insert and slightly twist a plastic opening tool to separate and remove the backing of the Chromebook from the body.
    • Do not immediately remove the back from the laptop. The power strip keeps the backing attached to the rest of the laptop. Gently lift backing from the power button side and set next to the body of the laptop.
  3. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 3, Bild 2 von 2
    • Remove two 4.6 mm JIS # screws at each end of the battery.
  4. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull out the ribbon cable attached to the motherboard that runs wires to the battery.
    • Remove the battery.
  5. Acer Chromebook CB5-132T-C8ZW USB Port Replacement, USB Port: Schritt 5, Bild 1 von 2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement, USB Port: Schritt 5, Bild 2 von 2
    • From the back panel, remove one 3.4 mm JIS #1 screw.
  6. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 6, Bild 2 von 2
    • Remove the white connector strip using your fingers.
  7. Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook CB5-132T-C8ZW USB Port Replacement: Schritt 7, Bild 2 von 2
    • Lift the USB port up using a spudger.
    • Remove the USB port with your fingers.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 570
