Zum Hauptinhalt wechseln
Acer Chromebook CB5-312T-K 8Z9 Battery Replacement
Was du brauchst
  1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: Schritt 1, Bild 2 von 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: Schritt 4, Bild 3 von 3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
Abschluss
Alonso
224 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 1,554
