Was du brauchst
First begin by flipping the laptop on its back and having the back cover face you directly.
Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
Identify the port that is connected to the speaker.
Using tweezers, separate the cable from the port.
Remove the black tape from the port.
Identify the two Phillips screws.
Remove the two screws holding down the board with a J1 Phillips screwdriver.
Gently lift the board from the Chromebook.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Any ideas about where to purchase this part? I am almost certain that it is the problem with my sound. Also, I can get to it no problem, but I am struggling finding a replacement part.
I have looked on numerous pages on google, both with the part number and with the Chromebook model number and have yet to be able to find a supplier.
