Zum Hauptinhalt wechseln
Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement
Was du brauchst
  1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: Schritt 1, Bild 2 von 2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: Schritt 3, Bild 3 von 3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 4, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 4, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 4, Bild 3 von 3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
  5. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: Schritt 5, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Begin by locating the speakers.
    • Once you have found where the speakers are, direct your attention to the speaker to the left of the mouse pad.
    • Grab your tweezers and begin disconnecting the wire that connects the speakers to the circuit board on the upper left corner.
  6. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 6, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 6, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Locate where the mouse pad would be, this should be relatively easy as it will be right in between the two speakers.
    • Start peeling off the black tape that is covering the speaker wires.
    • Fold back the cables that are on top of the wires for easy removal of the speakers.
  7. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: Schritt 7, Bild 3 von 3
    • Direct your attention back to the speaker that you were first working with in step 5.
    • Start by pulling up on the speaker, it should simply come right out.
    • Repeat this for the right speaker.
    • Once the two speakers are removed, unhook the wires from any clips that may be holding it to the computer.
Abschluss
Kyle
125 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 499
