Zum Hauptinhalt wechseln
Acer Chromebook CB5-571-C5XU Battery Replacement
Was du brauchst
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB5-571-C5XU Battery Replacement: Schritt 2, Bild 2 von 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: Schritt 4, Bild 1 von 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the battery out and remove it from the laptop casing.
Abschluss
To reassemble your device, follow these guidelines in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
Kenneth Bowers
1.432 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 869
