Einleitung
One of the device's most important parts is the fan, as it helps keep the processor cooled and stops the computer from overheating. A fan might need to be replaced due to it being noisy, broken, or damaged, and this guide will help replace the fan.
Was du brauchst
Remove the following eighteen screws using a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, unscrew the screw to the right of the fan.
Using the Phillips #0 screwdriver, unscrew the four screws connecting the heatsink to the motherboard.
Using the spudger tool, carefully remove the wires connecting the fan to the motherboard.
Using the flat side of the spudger, firmly pry the fan off of the components, as well as the heatsink from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
