Was du brauchst
Remove the following eighteen screws using a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
Gently slide the black ribbon out from its socket and under the white ribbon.
Carefully remove the smaller black ribbon from the motherboard using the opening tool.
Simply lift upwards on both speakers, and they will remove from their position.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
