Zum Hauptinhalt wechseln
Acer Chromebook CP5-471-C0EX Fan Replacement
Was du brauchst
  1. Acer Chromebook CP5-471-C0EX Fan Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Fan Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 2, Bild 3 von 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 3, Bild 2 von 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Fan Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Fan Replacement, Battery: Schritt 4, Bild 2 von 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Fan Replacement, Fan: Schritt 6, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Fan Replacement, Fan: Schritt 6, Bild 2 von 2
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 7, Bild 3 von 3
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  8. Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 8, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 8, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 8, Bild 3 von 3
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  9. Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 9, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 9, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Fan Replacement: Schritt 9, Bild 3 von 3
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Gateway, Team 1-1, Saknee Spring 2022 Mitglied von Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 236
