Zum Hauptinhalt wechseln
Acer Chromebook CP5-471-C0EX Trackpad Replacement
Was du brauchst
  1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 3, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 3, Bild 2 von 2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: Schritt 4, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 5, Bild 1 von 1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: Schritt 6, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: Schritt 6, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: Schritt 6, Bild 3 von 3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  7. Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 7, Bild 1 von 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 7, Bild 2 von 3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 7, Bild 3 von 3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  8. Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 8, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 8, Bild 2 von 2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 9, Bild 1 von 2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: Schritt 9, Bild 2 von 2
    • Carefully remove the trackpad from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Gateway, Team 1-1, Saknee Spring 2022 Mitglied von Gateway, Team 1-1, Saknee Spring 2022
GCC-SAKNEE-S22S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 227
