Einleitung
This guide will show you how to replace the Wi-Fi card in your Acer Chromebook CP5-471-C0EX laptop. If you’re having trouble connecting to Wi-Fi or experience frequently dropped connections, you may have a faulty Wi-Fi card. The laptop will also fail to detect any wireless connection even when such networks are available. The operating system may also fail to recognize the Wi-Fi card. Replacing or re-setting the wireless card may fix it.
The Wi-Fi card provides the laptop with a dedicated, full-time connection to a network.
Make sure to power down your device and disconnect from any power sources before you begin.
Was du brauchst
Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
Carefully detach the ribbon cable connecting the battery and the motherboard.
Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
