Zum Hauptinhalt wechseln
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
Was du brauchst
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: Schritt 1, Bild 1 von 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: Schritt 1, Bild 2 von 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: Schritt 2, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: Schritt 2, Bild 2 von 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: Schritt 4, Bild 2 von 2
    • Carefully slide the wireless card out of its socket from the motherboard.
Abschluss
Gateway, Team 1-4, Saknee Fall 2021 Mitglied von Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 314
