Einleitung
Removing the battery may be necessary if the Chromebook experiences power issues or if the user wants to replace an old battery. It is important when removing the battery to unplug your device charger as well as making sure the computer is turned off. Do not place the battery near any liquids or metal devices as they may harm the battery or cause the battery to discharge.
Ersatzteile
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
Find the seam along the edge of the device.
Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
Remove the two 4.5 mm Phillips screws located at the sides of the battery.
Grip the battery connection using two plastic opening tools.
Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
3 weitere Nutzer haben diese Anleitung absolviert.
