Zum Hauptinhalt wechseln
Acer Chromebook R11 CB5-132T-C1LK Camera Replacement
Was du brauchst
  1. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: Schritt 1, Bild 1 von 2 Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: Schritt 1, Bild 2 von 2
    • Insert the metal spudger into the groove on the edge of the screen.
    • Carefully slide the spudger from one corner to another.
    • When there is room for a finger, remove the screen by gently lifting it out of the computer.
  2. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a heavy duty spudger, lift the camera off the screen base.
    • The camera will be connected to the base with an adhesive.
  3. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: Schritt 3, Bild 1 von 1
    • Unplug the camera from its port.
Abschluss
Cal Poly, Team S23-G2, Livingston Spring 2017 Mitglied von Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Hi Elizabeh, can you do a tutorial to change the mic on this chromebook?
There was a production batch of this chromebook that had a problem with the mic. So a lot of people could benefit from this.
Cheers!
Álvaro Guzmán Parrochia - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 502
