Einleitung
If the LED lights of your Acer Chromebook R11 CB5-132T-C1LK are not functioning properly, this guide will detail how to access and remove the LED board for replacement.
Ersatzteile
Keine Ersatzteile angegeben.
Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
Find the seam along the edge of the device.
Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
Pull the ribbon cable from the ZIF connector using tweezers.
