Was du brauchst
The back cover of the R11 is held into place using 11 screws.
To remove, use a screwdriver appropriate for a JIS 1 screw.
Battery is located in the bottom half of the computer.
Unscrew the two screws holding the battery in place. There is one on each side of the battery.
Slide out the ribbon that is connecting the battery to the motherboard.
There are 7 wires leading to it, and each is a different color of the rainbow.
Disconnect the keyboard ribbon located at bottom center of motherboard.
Slide out black ribbons connecting speakers to motherboard
Connected on lower left-hand side of motherboard
When removing wires, remove gently with respect to metal clips along wires that are holding them in place.
Slide out white ribbon connecting keyboard to motherboard
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
