Einleitung
This is how to replace the rechargeable battery. If you notice that your computer isn't keeping a charge, or doesn't work off of a charger, it most likely needs a new battery.
Was du brauchst
Unscrew the 12 back screws, circled in red. The top 8 screws are 4.90mm x 5.71mm.
The 4 blue screws on the bottom are 4.81mm x 4.6mm.
Using an opening pick, unclip the lips that are located around the edges of the device.
Looking at the inside of the device, locate the battery plug, and remove it.
The clip connector should pull out after a little bit of force is applied. But do not pull on the wires, pull on the white plastic part.
