Zum Hauptinhalt wechseln
Einleitung
This guide will help you successfully remove the microphone out of your Acer Chromebook Spin 15 CP315-1H-P1K8. If the microphone component for this laptop is not functioning, use this guide to properly remove the faulty microphone for replacing.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure the device is fully powered off. Flip the computer over so that the back is facing up.
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Use the iFixit opening tools as wedges to pry the back of the laptop off. Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back. Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop. Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Unplug the camera/microphone ribbon cable from the circuit board. Remove the single 3mm Phillips #1 screw from the Intel core. Unplug the cable from the circuit board.
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
  5. Use the plastic opening tool, create a gap  between the  back and front of the display. Lift the front out with your hands. Lift the front out with your hands.
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
  6. Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
    • Remove the two 3 mm Phillips #1 black screws from the microphone at the top of the display cover.
  7. Remove the microphone component from the rest of the computer by detaching the connected wire. The camera component of the laptop is connected to the same wire, so remove this as well.
    • Remove the microphone component from the rest of the computer by detaching the connected wire.
    • The camera component of the laptop is connected to the same wire, so remove this as well.
    • The camera is only held down with adhesives, so there is no need to use any tools.
  8. Remove the microphone and camera  wire out from around the display screen. Remove the ribbon cable at the bottom of the display screen to completely free the wire.
    • Remove the microphone and camera wire out from around the display screen.
    • Remove the ribbon cable at the bottom of the display screen to completely free the wire.
    • Carefully remove the adhesive tape and take out the ribbon cable.
  9. Remove the microphone from the laptop. Remove the microphone from the laptop.
    • Remove the microphone from the laptop.
Abschluss
Ian Sullivan
116 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 5
Letzten 30 Tage: 10
Insgesamt: 363
