Zum Hauptinhalt wechseln
Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement
Was du brauchst
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Battery: Schritt 3, Bild 3 von 3
    • Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the laptop by hand.
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement, Touchpad: Schritt 5, Bild 1 von 1
    • Detach the ribbon cable from the touchpad.
  6. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 6, Bild 2 von 2
    • Remove the tan adhesive tape that is covering the touchpad to expose the screws holding it in.
    • Remove the three, 3mm long screws that are holding the touchpad in place.
  7. Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook Spin 15 CP315-1H-P1K8 Touchpad Replacement: Schritt 7, Bild 2 von 2
    • Gently push the touchpad out with your hand.
Abschluss
Evan Costa
503 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G1, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 7
Insgesamt: 401
