Zum Hauptinhalt wechseln
Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement
Was du brauchst
  1. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the eleven 2.4 mm screws securing the back plate and internals of the Chromebook using a Phillips #1 screwdriver.
  2. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use an opening pick to remove the backplate of the laptop revealing the internals of the Chromebook.
  3. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Display Assembly: Schritt 3, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement, Display Assembly: Schritt 3, Bild 2 von 2
    • Remove the six 2.4 mm screws from the hinges using a Phillips #1 screwdriver.
  4. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Flip up the hinges on each side that were previously secured down by the screws.
  5. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 5, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Carefully detach the blue, yellow, and black wires from their connectors.
  6. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 6, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 6, Bild 2 von 2
    • Remove the electrical tape from the black connector and gently remove it from the socket.
  7. Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 7, Bild 1 von 2 Acer Chromebook Spin 511 (C741L) N20Q8 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • The base and display assembly are now able to be separated. Simply pull and remove the display assembly from the base of the laptop.
Abschluss
Lauryn F
710 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 66
